speed of scripts
manecante
Unread post by manecante » 16 Nov 2010, 15:51
hello
just trying out scripts in usine.
the one below is very basic, it just connects one output to an input.
(in a nearly empty patch, just 2 subpatches with dummy ins/outs).
it works but it takes nearly 1 second to connect/disconnect.
so:
- is it because of some code uglyness or is that intended (i.e. this method should *not* be used in an audio context) ?
- the same thing in a "Send Usine Internal Messages module" does not have this problem (but is much less flexible).
thanks for your hints.
Code: Select all
[snip]
BEGIN
  if (n = InCmd) then begin
    if (GetValue(InCmd) = 1) then begin
      cmd := 'CREATE_LINK';
    end
    else begin
      cmd := 'DELETE_LINK';
    end;
    SendInternalMsg ('SET_TARGET_PATCH','SENDER_PATCH');
    SendInternalMsg ('SET_TARGET_PATCH', '1', '1');
    SendInternalMsg (cmd, 'foo', 'output', 'bar', 'input');
  end;
END;
Unread post by 23fx23 » 16 Nov 2010, 16:17
globally IML is not targeteted at real time audio applications, even if it can performs very decently very fast, in some data cases
as i saw with the vst automations send via IML, however i feel the thing that can be really slow here is the
the process of creating/deleting wires or modules, cause it's not a priority process and take a certain amount of time.
maybe try in init to set InCmd FastCallback using
SetFastCallback(inCmd, TRUE); and disable undo could speed up a bit the thing, but not sure it can be really increased.
(don't remember but there is a command to send for usine to bypass undo, think it's in wiki)
I feel such 'audio Dispatcher' would work better with a real modules wiring indeed.
IML could be cool for adaptative changing setup, but not real time audio switcher.
as creating/deteleting wires is not as efficient as changing a dispatcher nb.
manecante
Unread post by manecante » 17 Nov 2010, 19:43
thanks for your advices, that's more clear for me now ;)
Unread post by senso » 17 Nov 2010, 19:59
yes this part of the IML is processed as a very low priority task.
In an audio process it can be used only in extreme circumstances.
But it's an interesting way to explore!
