Routing mobius vst "out" to Usine's "Tracks"
javanaiz
Unread post by javanaiz » 12 Nov 2010, 23:15
Hello !
I'm trying to route VST Mobius's multiple "out" to a Usine "tracks"
Mobius is a virtual vst looper.
I 'd like to make it work this way :
On "Track 4" is Mobius vst
Then
"out 1"' (from mobius vst module) goes to "track" 1
"out 2"' (from mobius vst module) goes to "track" 2
"out 3"' (from mobius vst module) goes to "track" 3
Is there a way to do it ?
Note : on the right side of the picture are some of the module I tried to use unssucssfully
thanks j.
Unread post by nay-seven » 12 Nov 2010, 23:40
hé hé javanaiz..always fighting with Mobius..? ;-)
the send to new audio bus would be the solution, you'll have then out1,out2...
then in track 1 use the get from existing bus from your effect audio in or whatever you have in this track and choose out 1
i can add screenshot if needed
check here too about target for buses
gurulogic
Unread post by gurulogic » 13 Nov 2010, 19:57
maybe too much information for now, but if you want phase perfect audio sync between the direct outs (1&2) from Mobius and the bus tracks from mobius, you should delay the direct outs by one bloc as the bus audio is always automaticly delayed by one bloc. (buffer)
javanaiz
Unread post by javanaiz » 13 Nov 2010, 23:48
Hey Nay 7
yes I'm still strugling with Mobius ;)
I don't know what I got with Busses.
I always forgot about the way it works
Thanks it works fine with your help !
I also found the tutorial about "Communication between patches and tracks"
really nice about how it works
http://sensomusic.com/wiki/doku.php?id= ... h:chapter3
Gurulogic : thanks about pointing this,
but how do you do to delay the direct outs by one bloc in Usine
Unread post by oli_lab » 14 Nov 2010, 08:42
isn't it "wait one cycle" ?
unguitar
Unread post by unguitar » 17 Nov 2010, 22:57
nay-seven wrote:hé hé javanaiz..always fighting with Mobius..? ;-)
yes for the screenshot, please ( and thanks)
______________
luca
www.unguitar.com
Unread post by nay-seven » 17 Nov 2010, 23:48
no problem:
Users browsing this forum: No registered users and 637 guests
