drag and drop samples to VST from browser?
right, works from a windows window, not from the window browser
must be a question for senso..
yes exactly. And if using the windows browser then there is no sample preview before loading unless you open the file in an audio player which i'm not sure will work because usine is using the soundcard?. I hope the boss has plans for this?
is it humor?
Each DAW as it own browser management.
Can you drop a file from FLStudio to Ableton Live?
Can you drop a wave file from Live browser to Windows Explorer or NIBattery file list?
etc...
Shortcircuit doesn't accept Usine's browser files. That's all! And will never!
etc...
If it can't/won't be done then that is fair enough. For anyone who is interested I've found a good solution. It is called tackybrowser by modulr (subliminal.org). It is a VST plugin that acts as a browser which lets you preview samples and drag and drop to VST and works perfectly in usine. http://www.gersic.com/plugins/hosted/su ... -v1.00.zip
