Set Several Array Value at the same time
manecante
Unread post by manecante » 08 Nov 2010, 15:05
hello,
i am trying to set several array value at the same time but it does not seem to work as soon there is more than one..
Here is my patch :
Unread post by bsork » 08 Nov 2010, 15:27
You should have the SetArrVal modules in series, not parallel. Or do you eventually have something more complex in mind? The reason I ask, is that the two extra Array modules aren't needed in the example, but they might have some other use(?).
manecante
Unread post by manecante » 08 Nov 2010, 18:10
Hi Bsork!
Thank's a lot for your answer, works perfectly for my need. And about the two extra arrays, they were just there to debug..
And i have another question for you as i have seen on KVR forum that you already manage to connect Usine to Jack, but it was 3 years ago, i think..
I hope secretly that you missed my post and might have a clue of what to do :)
http://www.sensomusic.com/forums/viewtopic.php?id=2523
Sorry for the off-Topic ....i could not resist...
Unread post by bsork » 09 Nov 2010, 08:39
Good that you made the SetArray work!
Users browsing this forum: No registered users and 63 guests
