Anyone using this?
It wraps individual VST programs, so you can put programs from different vsts in one bank. Then it loads the correct VST when you select the program.
It seems like a very promising approach for me, but it 's constantly crashing for me. Wondering if that's a usine compatibility prob, or something in my setup....
anyone tried WusikVM??
yes, crash here too ( quick test on my vsita sp2 machine )
It used to work ok for me but did not want to work the last time I used it (v5?)
Pretty cool, if used with a preset manager it could also load vsts from Usine preset selection. This is one of my feature suggestions for Usine... a vst load module!
Users browsing this forum: No registered users and 414 guests
