Hello !
Which are the best module I should i use in order to create a patch for recalling by a preset different time signature : for example moving to 4/4 to 21/8 ?
And at the same time different tempo values ?
Thank you !
Changing the time signature with a preset
hi little mouse . for that you can use the master sync module located in /sychro_and_time.
, pick some faders out of it , it ie tempo, cycle length ect.
then add a preset manager, make your settings , store a preset, change settings, store new preset ect...
noise2sine
Great thanks !
But i couldn't move to 21/8 it stays only in 21/4 ??
Usine only has 4 as the nominator, so you would have to also double the tempo to simulate the use of 8ths.
noise2sine
Is there any chance of having 8 or 2 or 16 as the nominator ??
Users browsing this forum: No registered users and 25 guests
