Smooth Joggle Pack
Smooth Joggle Pack (24 Ko)
by senso Posted on 2010-10-06 16:03:48
This pack contains 5 examples of patches made with a Smooth Joggle scripts. The main purpose of those scripts is to provide a smooth change of the Sampler/grainSampler reading position.
1) XY Pad, like a kaos pad with
X axis = sample position
Y axis = pitch (-24 at the bottom, +24 at the top)
2) Sample Scratcher
Follow and scratches the sample according the mouse (finger) position. Plays the sample only if the mouse is pressed.
3) Ribbon GrainSampler
Follow the sample according mouse position. Plays the sample only if the mouse is pressed. Can be used as a "Ribbon player".
4) Simple GrainSampler with smooth position changes
5) Simple Sampler with smooth position changes
Patches are very simple, and can be easily modified and included in your setup.
2) Sample Scratcher
thanks a lot for these! this perfectly showcases usines sample mangling abilities.
really strange manecante..
I've send you the patches by mail...
thank you nay!
heu...do you mean it comes from me when you say "very strange"???
I tried as well with the computer of my friend (on linux) and it is the same, it says the file is empty...I am using 7 zip to extract file on windows and have no problem to open other zip.
Does anyone else get the same problem? i am starting to be parano now..
i can open it with winrar and 7zip ( v 4.65 ) without problems, so yes , it's strange..
the file is 25 Ko , same for you ..? cause maybe a download problem..?
It's a server maintenance problem, finished and solved now.
sorry.
sorry.
multiphone
Hello Senso,
Very efficient add-ons !!!
Thanks for this scripts
Users browsing this forum: No registered users and 84 guests
