Usine 5.25e
Announcements
Unread post by senso » 06 Oct 2010, 14:52
[large]Usine 5.25e[/large]
This version fixes several details in the sequencer and the VST version installation.
It's a minor update, you can skip this release if Usine works fine for you.
[large]fixed bugs[/large]
- [sequencer] sometime the first notes of a midi file are not played definitively solved.
- [VST version] "no SPlib dll feature was found in the waterfall procedure" during scanning of VST folder
Systematic
Unread post by Systematic » 06 Oct 2010, 20:20
Excellent work. Thank you!
Error completely gone, so i'm off to enjoy this new tool. Thanks.
