I Super Usiners ! ! !
I've made patch and i've seen that we can't load directly a new list...It could be great to have an instrument and called speedly different list and keep the instrument intact..in sort we could change the bank of sound.
I've try with the preset manager but it doesn't works... When i'used Battery for exemple it was possible with the preset manager. i could change very instantly..
Does i mist something in the forum ?
is it a pertinent question?
Music Music Usine Usine Usimc
A function to make a toggle "next list" in sampler and grain sampler
You can do like this:
To go quickly, you can put a sampler where you put your sample and get the list from the outlet commatext in a text module
Seb.Dub
Hy Seb
ThhaaAAANNnnKKssss a lllLLLLoooOOOTTTT
You save me ! ! !
Your exemple give me directly new way to create
Best
Simonakimou
You save me ! ! !
Best
Simonakimou
Users browsing this forum: No registered users and 70 guests
