matrix exclu mode and preset manager
ethnix73
Unread post by ethnix73 » 24 Sep 2010, 11:16
I'm facing a problem with the matrix and the exclu mode patch.
When using the matrix in this mode, the preset manager does not seem to work.
Am i doing something wrong, or if not does somebody has got a workaround?
Seb.Dub
Unread post by nay-seven » 24 Sep 2010, 12:05
talking about cells on / off , you're right..
works time to time 1/10 , maybe martin can answer this..
sorry no workaround right now..
Unread post by nay-seven » 24 Sep 2010, 12:08
just found : add a pass if change between the out of the sub-patch MX_exclu_mode to the in of the matrix, seems working...
edit :hmm, not really well , you have to click twice sometimes...sorry
ethnix73
Unread post by ethnix73 » 24 Sep 2010, 12:15
Thanks for your answer nay-seven.
But in my patch, this workaround does not work. Maybe because i set the cells from an external controller...So it seems that the preset manager is only able to store the last set cell.
Seb.Dub
ethnix73
Unread post by ethnix73 » 24 Sep 2010, 12:43
I have perhaps found a workaround by storing the value of the matrix in an array, and stopping the flow from the matrix to the array when using the preset manager...
Seb.Dub
Unread post by nay-seven » 24 Sep 2010, 12:48
cool, gone to test this later
Users browsing this forum: No registered users and 41 guests
