use a button to send midi notes?
tpresto
Unread post by tpresto » 19 Sep 2010, 02:38
Here's a question that likely has an incredibly simple answer. How may I send multiple midi notes to a synth (in this case, addictive drums) by pressing a single button? Also, I'm a noob, and am looking for information on the included modules -- like when, why, and how to use logic modules (i.e. not, or, xor, etc) and the event control modules (i.e. toggle, from 1 to 0, pass if change, etc) and how they work, so that I can become proficient enough to figure this type of thing out for myself.
Unread post by 23fx23 » 19 Sep 2010, 06:27
hi tpresto. you can create several modules "create midi message" set them to the message you want and
connect all their 'create inlet' to your button same button. than all their midi out to midi outlet.
Unread post by nay-seven » 19 Sep 2010, 11:57
you can also explore sub-patch like midi/midi interface objects/midi seq note
about logic module, I'm working on a second manual part about patching
waiting for this you can yet check the lesson 08 of the learn Usine
waolelaid
Unread post by waolelaid » 19 Sep 2010, 19:45
Hi , very good idea Nay with examples it'll be fantastic
good evening :)
Friedrich Nietzsche
tpresto
Unread post by tpresto » 19 Oct 2010, 23:10
Nay,
Thanks for the advice, I got it up and working after a long time away from Usine and my computer.
