Track audio input
bmoussay
Unread post by bmoussay » 01 Feb 2007, 22:45
Hi just a small suggestion:
In the list of available audio inputs for a track, I think it would be cool to have also the possibility to select:
- Out 1, out 2, 3,4,5, etc...
That would allow some really crazy, but also sometimes very practical audio routing (like for instance sampling usine's audio output, while having at the same time some other "insert patch" etc... )
What do you think?
Rgds,
B.
Unread post by senso » 02 Feb 2007, 17:33
Of course not impossible but dangerous! (feedbacks).
Don't you think that 'audio bus' can do the job?
bmoussay
Unread post by bmoussay » 02 Feb 2007, 18:26
Actually you're right, maybe it's too dangerous.
I just hadn't thought about simply putting a "send to audio and data bus" in the insert patch, that is exactly the same, but more secure!!!
Rgds,
B.
