Possible usine VST bug snap crackle pop on track 4?
Can anyone confirm this? in the latest Usine free VST, add a sampler to track 1 in a new workspace and load a loop. play in loop mode. output to track as normal but also bus the output to tracks 2,3,4. In your VST host set up 4 tracks with an instance of Usine VSTi on each track. The first 2 tracks seem to play fine but the 3rd track seems to have some minor glitches and the 4th track has some nasty glitches happening. This was tested in Audiomulch and in Reaper with the same result. I think track 3 is not as bad as track 4. Anyone else?
confirmed, will be fixed in the next release.
sorry for this point.
But, in the future, can you send bug reports by mail?
thanks+++
thanks+++
Users browsing this forum: No registered users and 53 guests
