using usine more and more...i really love it
some idea for the sampler
1. sometimes when moving start and end point (if the playing speed is pretty low) i can hear bad crackling (sometimes i like that...sometimes not)
so would be very good to have the option to avoid that
i.e. an inlet in the sampler like "don't update loop points when you are moving start/end ..update when the relevant controls stop moving"
2. would be vary nice to have a "auto normalize samples" option
3. the waveform display..
would be nice to have start and end handles on the waveform itself
4. the waveform display again...
as it is now it visualize only what is between start and end points
would be good to have the option to "visualize the entire sample"
and having a "zoom factor (x and y axis)" for the display itself
5. would be nice to have a new gui control widget like a drop-down menu
containing the sample list...so you can load the sample directly by its name
6. drag and drop samples from library to the waveform display to load a sample in the sampler
what do you think guys?
thanx
Some idea for the sampler and the wavorm display
- senso
hello, thanks for your feedback.
I have improved this point in the next version: no more click...1.so would be very good to have the option to avoid that
The normalization can take a long time, if the file is big, or if it'snt loaded in memory. Also, you can easilly create a subpatch that 'auto normalize' the sample: find the maximum of the incomming sound an modify the sampler gain.2. would be vary nice to have a "auto normalize samples" option
Done in the next version. And now you can have the wave form in a big resizeable window or let it in the control panel.3. the waveform display..
done, next version: "visualize the entire sample"; zoom not yet...4. the waveform display again...
Good idea. let me think about it.5. would be nice to have a new gui control widget like a drop-down menu containing the sample list...so you can load the sample directly by its name
Good idea (again). let me think about it.....simpler than 5.6. drag and drop samples from library to the waveform display to load a sample in the sampler
lalo
wow!
