I couldn't find the location menu as writen in the manual,in order to read a long wave file from the hard drive ? where can i find it ?
Thank you
Sampler and Ram
can you point me to this part of the manual..? can't find it right now..
maybe this refer to the alternate drive choice ( global setup/interface)
it is not a menu, is an option inside the sampler module instead:
noise2sine
Ok , i was using an old sampler patch (V.4) and i couldn't find this. I have upgraded my sampler patch and it's fine
thanks
thanks
Users browsing this forum: No registered users and 405 guests
