Usine 5.25 beta 6
Announcements
Unread post by senso » 15 Aug 2010, 19:18
[large]Usine 5.25 beta 6[/large]
Probably the most important update since the v5. It contains many important improvements and fixes several important bugs.
Usine 5.25 is AIFF compatible, globally faster and takes less memory.
It is still announced as a beta version but after, few buses issues corrections, the beta6 is now very stable
You should download it.
[large]improvements[/large]
beta 6:
- the Delay module sounds better.
- new Compile&Init and Compile&Reload menus for scripts
- few new IML instructions: PAUSE, CREATE_UID, GET_CAPTION
- VST Randomizor template added
beta 5:
- Aiff sound files compatible
- Zero crossing is active now in the sampler during the recording process, if the option is activated.
- better audio quality and synchro in the Grain Generator module
- new on/off parameter in the send bus module
- Midi-learn is now allowed on all the buttons of the navigation bar in IB mode
- better size adjustment when moving/resizing controls.
- new browser/Add-ons design
- new protect mode as hidden string
- better Audio to Midi (pitch tracker) sub-patch
- new Active Line Number module, to get the selected line in the grid
- new navigation bar design (IB mode)
- new Midi Expand voices Midi Tool script
- new Math/Bit Operators OR, AND, XOR, NOT, SHL, SHR available as scripts
- new improved Random Law Generator sub-patch
- new options in the global IB "maximize if ON (Grid & IB)" and "maximize if ON (IB only)"
- Usine graphic engine is globally twice faster.
- Scripts take less memory
- audio protection in the Filter module to prevent instability
- new target parameter in the mouse module
- new SET_LAYOUT instruction in the IML
- new FaderColor Module.
- in the Sequenced Pianoroll, we can now scroll the cursor position.
[large]fixed bugs[/large]
- problems with negative numbers in the RandomData module
- the 'edit layout' function is sometime tricky...
- various graphic refresh problems when the ASIO driver is down
- small refresh issue in the preset panel on recall
- sometime Midi/Key learns aren't properly stored in the patch
- often, the Midi setup is lost...
- the Midi Sequencer diplicates Midi Events in bar mode
- various conductor issues with copy/past bank
- refresh problem when a VST window is reduced as a thumbnail
[large]comments[/large]
- the scale parameter of Faders/Knobs is no longer in the layout settings but is now in the module settings (as it use to be in the V4)
- the color selector is now opened with a double click instead of single click.
trik
Unread post by trik » 01 Sep 2010, 18:09
the new version gives me distorted audio output. i changed various audio settings but nothing helped. changing the buffer size changes the sound of the distortion.
can you put up older versions of the free version for download so i can find out wich one works?
i'm using a single core athlon 64 and a esi quatafire soundcard.
Unread post by senso » 01 Sep 2010, 18:44
Generally this kind of issues comes from a conflict between the Asio engine and the 'Microsoft Wavetable synth" midi driver or something like that. Check your midi settings.
I'll restore older usine version for download.
Edit: for internal reason I can't restore the v5.20b free, sorry, but thrust me your pb is somewhere else...
Debutante
Unread post by Debutante » 02 Sep 2010, 04:28
trik wrote:the new version gives me distorted audio output. i changed various audio settings but nothing helped. changing the buffer size changes the sound of the distortion.
I'm egtting the same thnig using either ASIO or the primary driver in my system. I tried to cjhange Usine and card MIDI settings to no avail. What particular settings are you recommending we change?
FL STUDIO 9.1
WinXP Home SP3
Phenom X4 II 940
ASUS M4N78 Pro
(ASIO4All, WDM) - OR - E-Mu 1212M ASIO
Unread post by nay-seven » 02 Sep 2010, 09:25
hello and welcome
asio 4all work in 99% of the case but as say senso , Microsoft Wavetable synth is often the problem
1 - rightclick on your volume icon in the bottom right corner
2 - go to playback devices
3 -check for 'Microsoft Wavetable synth
4 - disable it (don't worry you can reverse this easily at any time)
Unread post by senso » 02 Sep 2010, 19:46
The glitches issue of UsineVSt in FLStudio will be solved in the beta8
