Usine v5.25 beta 5
Announcements
Unread post by senso » 13 Aug 2010, 18:31
[large]Usine 5.25 beta5[/large]
Probably the most important update since the v5. It contains many important improvements and fixes several important bugs.
Usine 5.25 is AIFF compatible, globally faster and takes less memory.
It is still announced as a beta version but after, few buses issues corrections, the beta5 is now very stable
You should download it.
[large]improvements[/large]
- Aiff sound files compatible
- Zero crossing is active now in the sampler during the recording process, if the option is activated.
- better audio quality and synchro in the Grain Generator module
- new on/off parameter in the send bus module
- Midi-learn is now allowed on all the buttons of the navigation bar in IB mode
- better size adjustment when moving/resizing controls.
- new browser/Add-ons design
- new protect mode as hidden string
- better Audio to Midi (pitch tracker) sub-patch
- new Active Line Number module, to get the selected line in the grid
- new navigation bar design (IB mode)
- new Midi Expand voices Midi Tool script
- new Math/Bit Operators OR, AND, XOR, NOT, SHL, SHR available as scripts
- new improved Random Law Generator sub-patch
- new options in the global IB "maximize if ON (Grid & IB)" and "maximize if ON (IB only)"
- Usine graphic engine is globally twice faster.
- Scripts take less memory
- audio protection in the Filter module to prevent instability
- new target parameter in the mouse module
- new SET_LAYOUT instruction in the IML
- new FaderColor Module.
- in the Sequenced Pianoroll, we can now scroll the cursor position.
[large]fixed bugs[/large]
- problems with negative numbers in the RandomData module
- the 'edit layout' function is sometime tricky...
- various graphic refresh problems when the ASIO driver is down
- small refresh issue in the preset panel on recall
- sometime Midi/Key learns aren't properly stored in the patch
- often, the Midi setup is lost...
- the Midi Sequencer diplicates Midi Events in bar mode
- various conductor issues with copy/past bank
- refresh problem when a VST window is reduced as a thumbnail
[large]comments[/large]
- the scale parameter of Faders/Knobs is no longer in the layout settings but is now in the module settings (as it use to be in the V4)
- the color selector is now opened with a double click instead of single click.
Unread post by 23fx23 » 13 Aug 2010, 18:42
and new matrix? yeeeeahh killer addz.
Floego
Unread post by Floego » 13 Aug 2010, 18:44
Very good! Downloading...
Unread post by nay-seven » 13 Aug 2010, 18:52
great news , as always !
franck
Unread post by franck » 13 Aug 2010, 19:54
Cool good job Olivier
merci
franc et ses amis
Unread post by senso » 13 Aug 2010, 22:34
Midi buses issues Corrected in the beta 4.
Unread post by senso » 14 Aug 2010, 09:44
Audio Buses issues fixed in the beta 5
runagate
Unread post by runagate » 14 Aug 2010, 16:23
Amazing!
It's days like this that remind me that, though quiet, I actually do peruse the forums here almost every day.
multiphone
Unread post by multiphone » 14 Aug 2010, 20:02
Thanks a lot !
Usine grow.
HB
Lines / Points / Squares
http://www.hervebirolini.com/
