Need to reload to have ti working
oxyredox
Unread post by oxyredox » 30 Jul 2010, 08:02
I'm now working with version 5.20,
very good job by the way !
But I still have a very weird phenomenon that I had with the beta version and I thought would get away with the last update...
I just have two tracks,
Track 4 : A very simple patch called "LOADER" with two patch loaders for track 3, line 1 and track 3 line 2.
Track 3 : line 1 : a patch with Kontakt. line 2 Effects for Kontakt.
(Tracks 1 and 2 hold patches that manage MIDI datas from my keys that are loaded by patch loader in the Kontakt patch.)
The problem is each time I press the load button in "LOADER" I get this :
and I need to "crt-alt-R" reload the patch to have it correctly working :
That's very weird, I found out that to get rid of this problem, I had to have "kontakt FX" (track 3 line 2) loaded via the Kontakt patch and NOT via the LOADER patch.
Any Idea ?
Unread post by nay-seven » 30 Jul 2010, 10:20
looks like a bug , but the best way to check is to try to reproduce it in a simpler way to isolate the problem .
for example with the heliosII and some patches included in Usine
then if you can post the workspace here ( or send it directly to senso ) this could help to trace the problem..?
Unread post by senso » 30 Jul 2010, 10:42
this pb can appear when the loaded patch is heavy, or with a very big VST when the audio engine is ON, without any obvious reason...
It's a very rare bug but I'm working on.
oxyredox
Unread post by oxyredox » 30 Jul 2010, 13:58
Yes the kontakt VST is heavy,
I was wondering if there was an issue with the order the patches are loaded ?
What is the rule ? Is it graphical as in MaxMSP ? Chronological (depending on when the module was created)?
I can't turn the engine off and press the load button can I ?
By the way are you interested in having a look at the workspace ?
Are you interested in having a look at patch by the way ?
Unread post by senso » 30 Jul 2010, 19:56
yes send your wkp at contact@sensomusic.com with your logUsine.log file.
thanks++
