Hello all,
It seems that I'm too stupid to make the off-line manual working !
I've tried many different ways, but no luck at this time !
Does the '?' link in Usine goes always to the on line help ?
Thanks in advance for your help.
Len
Offline manual
- nay-seven
first , of course, you have to set the option in the setup/interface /use intern help window
but if there's a valid web connection , Usine will use it anyway ( i suppose it's since the the new addon tab who need it )and the online help will be used in priority
if you stop your web connection, intern help will be used
don't know if it's a feature or a bug....
- senso
the "use intern windows" determines if you want to use your default browser (OFF) or the Usine built-in browser.
By default, if you are connected to internet Usine opens the online help, and if not the offline version.
So, if you're always connected you'll open the online version.
- nay-seven
Strange cause most of the community and senso are in France too and we don't have any speed problems..?
- senso
anyway,
In the next release there will be an option in the set up to open off line manual even if you are connected to internet.
