Sampler list Grouped with continuous flow
noise2sine
Unread post by noise2sine » 23 Jul 2010, 13:03
Help needed!!!
I use quite a lot "the Sampler list Grouped" which can be found in the add on section.
As I’m working on a project consisting of illustrating scientific movies about micro biological organism. i was dreaming about a patch based on the structure of the “sampler list grouped” but with more features.
The general idea is: when a sample file is about to finish with an automatic fade out, the second sampler start automatically with a fade in and so on.
My idea consist of two samplers (Sampler list Grouped) linked together with start/stop option related to each over sample length.
For example : Sampler A plays a 60 sec file, I wish that at 50 sec, the sampler B starts with a fade in..... and then with a fade out, the sampler A stops at the end of the sample .
It would be nice to have a slider in order to set up the % of the finishing time on each sampler and as well for fade in and out time.
The goal is to create a continuous flow with random possibilities, smooth and totally independent.
Thank u
Unread post by nay-seven » 23 Jul 2010, 16:39
interesting...
here a first step, not perfect and you have to adapt it to the addon but it's an idea ...:)
you can choose the end of the sample in % ,and will have to play with fade duration
here
noise2sine
Unread post by noise2sine » 23 Jul 2010, 18:55
Yes that's exactly what i expected ! Thank u very much!
ethnix73
Unread post by ethnix73 » 23 Jul 2010, 20:23
Or another way, without lines, there.
For a lighter CPU use, you can replace busses with wire.I used them just to have a more clear patching...
Seb.Dub
Unread post by nay-seven » 23 Jul 2010, 23:45
well done ethnix !
really more clear !!
noise2sine
Unread post by noise2sine » 24 Jul 2010, 12:16
i really want to thank u both, because it's really perfect what you have done, and so fast.
Usine team ROCKS !
