VST/VSTi organizer
pgervais
Unread post by pgervais » 14 Jan 2007, 12:11
have a look at the SONAR 6 plugins organizer : it is usefull.
You can create folders, drag&drop plugs in them, give a frendly name to each plugs etc etc ....
when you have many plugins, it is very cool !
... just a little suggestion
Regards
Unread post by nay-seven » 14 Jan 2007, 16:04
for my part i've organise all my vst/vsti
it's easy to make some dir , drums , synth? , samplers , midi , effect
and move all your vst/vsti in the good folder
and then when you open vst in Usine you don't have a big list...
just my 2?...
Unread post by senso » 14 Jan 2007, 18:18
I do the same thing.
The Sonar approach seems to be very complex for what it does: just a VST organisation...
Users browsing this forum: No registered users and 122 guests
