Usine 5.17
Announcements
Unread post by senso » 01 Jun 2010, 19:18
[large]Usine 5.17
[/large]
Important update with several improvements and bugs fixed.
improvements
- master output soft clipping option in the setup.
- midi learn is allowed on curve settings of the sequencer.
- caption font size option in the ControlPanel layout.
- after an IB reorganisation panels are now in track order
- new SendInternalMessage procedure in scripts
fixed bugs
- GetSmptePos, SetSmptePos and GetLoopMarkerPos is missing in Script
- the main IB is not cleared properly
- we can't use several send Midi to Usine module at the same time
- various curve setting bugs in the sequencer
- various display bugs
Unread post by 23fx23 » 01 Jun 2010, 19:47
yeahhhhhhhhhhh can't wait to test it!!!!
multiphone
Unread post by multiphone » 01 Jun 2010, 20:55
Thanks Olivier !
The master output soft clipping option is very usefull.
Best
HB
Lines / Points / Squares
http://www.hervebirolini.com/
martignasse
Unread post by martignasse » 01 Jun 2010, 22:00
yup yup yup, all good stuff :)
PS : 23fx23, i note you are now a mad scripter ;)
Unread post by 23fx23 » 01 Jun 2010, 22:12
of yeah martignasse, it 's because im too much waiting matrix!!! ;) im just starting try to make one by script
just for entertainment. the new args are great!!. i tried to make something that creates modules, auto link them, spread color
and captions, well you know what i mean ;) mais fr "c ptet un peu bourrin les for i=0 to l sendinternalmsg create modules" non?ça crash usine, vaut mieux les creer tous d'un coup?)
i just tried the args for pos and size that's fun to make scalable things also...args will make some tasks much clear/easier, very cool add.
Unread post by nay-seven » 02 Jun 2010, 00:11
great !
thanks also for midi learn on curve settings of the sequencer
useful !
Clearscreen
Unread post by Clearscreen » 02 Jun 2010, 03:02
senso wrote:- master output soft clipping option in the setup.
COOL! very handy thing!
Unread post by bsork » 02 Jun 2010, 08:07
Thanks!
ethnix73
Unread post by ethnix73 » 02 Jun 2010, 11:11
Thanks mister Senso
Seb.Dub
Floego
Unread post by Floego » 02 Jun 2010, 18:54
Thank you
Users browsing this forum: No registered users and 5 guests
