reaktor & usine
lucenay71
Unread post by lucenay71 » 07 May 2010, 20:01
hello,
I use to insert native Absynth in usine and everything is doing well. But I'm a beginner with Reaktor and I cannot obtain any sound when I patch it in Usine. I do the same as my absynth patch and it doesn't work with the reaktor patch. Is there somebody who can help me ?
Thanks a lot
Unread post by nay-seven » 07 May 2010, 20:15
i don't have Reaktor myself ( except a free reaktor session one ) but i know that senso use it and don't have any problem..
maybe a screen shot of the way you patch it..?
Unread post by woodslanding » 08 May 2010, 09:42
yes, i use reaktor as vst inside usine all the time, and no probs.
What ens do you have loaded into reaktor? Make sure it uses the same outs you are patching from in usine.....
Users browsing this forum: No registered users and 136 guests
