faders---max above min?
If the max could be low and the min high, it would totally make working with drawbars 1000 times easier.....
(Still struggling to get the vst param script to work with reverse faders....)
La Tenaille
I was thinking about posting this one.
Wouldn't that be done like this? Or am I missing the point...
kara wrote:Fader with min 0 and max 100 goes to an (A-B) module where you set A=100 and B the input of your fader.
Is that what you want ?
k
another might be simple in some cases workaround: inverse fader and baground color gives a visual inverted fader, keeping normal wiring, or flip the jpg sequence image horizontally if jpg based..
Clearscreen
It'd be nice to be able to rotate elements in the IB - I've thought about that before...
Yeah, I've been able to work around everything (Lots of ABS(1 - x) everywhere)
except sending IML.
Still haven't figured that out. And maybe switching the fader values wouldn't help anyway.
except sending IML.
127 - (0->127) = (127->0)
(0->127) is the fader
127 - a box "-" in math, "127" in "a" and "fader" in "b"
(127->0) is the result (invert fader)
I post this patch the next week, good weekend
PatcherKit at work.
"REVERSED FADER" exemple is in add-ons pack (PatcherKit) in Data tools
PatcherKit at work.
Thanks jeanrene--I'm sure that will be useful.
I don't have problems reversing faders, though. My issue was addressing reversed faders via IML.
I figured that one out also (well, Bsork did most of the work!) and will post it, although it is quite a complicated solution.
-e
-e
...uh... I did?woodslanding wrote:I figured that one out also (well, Bsork did most of the work!) and will post it, although it is quite a complicated solution.
-e
Ummm.... I think it was you (?)
oop, sorry :/
Users browsing this forum: No registered users and 66 guests
