Custom Faders
BaKeRjCa
Unread post by BaKeRjCa » 29 Apr 2010, 07:04
Hey guys,
Created some custom faders for the DJ Mixer project I've been working on.
However, actually creating these took forever using one of the templates from Usine. Is there a software that can automate this process much like Knobman does for knobs?
Thanks!
Clearscreen
Unread post by Clearscreen » 29 Apr 2010, 08:27
They look great - wish I could help you!!
gurulogic
Unread post by gurulogic » 29 Apr 2010, 09:06
nay-seven gave me this tip awhile back. I have yet to try but I'll pass it on anyways.
http://www.g200kg.com/en/software/knobman.html
Unread post by woodslanding » 29 Apr 2010, 09:14
You can totally use knobman for faders.
You need to model the whole fader, not just the slider part.....
Maybe I'm missing something?
Unread post by 23fx23 » 29 Apr 2010, 11:57
maybe a bit more complex (not sure, i didn't fully try knobman) but adobe After Effects and/or Photoshop are also great powerfull tools for that. there are fully fonctional demos.
Can design each "layers" in photoshop ie the Bacground and slider, then import the PSD file and animate slider in after effect.
then just render desired nb of frames, it can be done in a few minutes if you're used to adobe products, but maybe knobman can do cool job on faders as well..
anyway they look good! keep on
Users browsing this forum: No registered users and 535 guests
