Problem with midi...
soundprizm
Unread post by soundprizm » 23 Apr 2010, 00:43
Hi... I'm using usine to trigger samples while playing a drumset. I have triggers going into an alesis dm4 that goes into a customized mackie spike via midi, that goes into Usine. Everything seems to be going ok, but when trying to trigger a sample via the "learn" switch it doesn't trigger every time. Seems like it just picks when it wants to play. The command bar is showing that Usine receives the midi message, and the "learn" switch is lighting up everytime I hit it, it just doesn't trigger the sound every time I hit it. What am I doing wrong? I have the interval at 0ms, and when I click on the play button for the sampler it works every time as well. Any help or suggestions is greatly appreciated!
soundprizm
Unread post by soundprizm » 23 Apr 2010, 01:44
Okay, I think I either found a bug or I have something set up incorrectly... because I tried doing the same thing with the button sampler patch. I set my trigger to the "midi learn" button and the same thing happens. The "midi learn" button lights up every time I hit the trigger, but the file does NOT play every time. When I click on the play button with the mouse the file DOES play every time. A bug?
Unread post by nay-seven » 23 Apr 2010, 02:03
try to right click on your switch , and try different remote options ( absolute,relative,toggle ),
soundprizm
Unread post by soundprizm » 23 Apr 2010, 05:56
Hey Nay, thanks for the reply! :)
Absolute= Same issue
Relative= Same issue
Toggle= Works the way it should (stops the file every time, starts the file every time)
soundprizm
Unread post by soundprizm » 27 Apr 2010, 04:44
I figured out my own problem!
The problem was that the "midi learn" I had in the container was a switch, so I changed that module to a button and now all is good. I guess switches cannot work with relative and absolute trigger modes.
Users browsing this forum: No registered users and 686 guests
