I would like to see Usine VST have direct access to all midi ports with similar midi in and out setup as Usine standalone.
The difference being that in Usine VST you could also select any of the 16 Usine instances as midi in and out ports.
I understand there can be conflict if VST and a host select the same midi port but this is easy enough to be mindfull of.
The advantages would be direct access to midi ports in Usine VST without having to configure midi inputs and outputs in the host if not really needed, possibly lower midi latency? bandwidth usage? and the ability to send midi remote (feedback) from Usine VST, plus greater flexibility in routing midi between Usine and the host.
Also, I think 8 possible midi ports is not enough for 2010. I think there should be at least 16 in both Usine versions!
Combined with my previous "add midi output" "add midi input" module suggestion, this would be a midi dream....
It is currently 28 Nov 2026, 07:01
Usine VST direct midi port access / more ports
Return to “Suggestions & improvements”
Jump to
- News
- ↳ News
- English Forums
- ↳ General discussion
- ↳ How to send a Bug Report
- ↳ Suggestions & improvements
- ↳ Patching questions
- ↳ Add-ons discussion
- ↳ Additional Packs
- ↳ Module development SDK
- ↳ Artistic Zone
- ↳ Registration procedure
- ↳ Manuals & Wiki
- Forums Français
- ↳ Discussion générale
- Home Board index
- All times are UTC+01:00
- Delete cookies
- Privacy
- Terms
- Contact us
Powered by phpBB® Forum Software © phpBB Limited
