bug usine on windows 7 on a mac
mitic
Unread post by mitic » 14 Apr 2010, 13:33
hello, I tried to use usine with windows 7 on a mac (macbook pro récent), 1st with asio4all driver, next with motu asio driver and my sound card motu 828mk2.
usine reconize drivers but I have no sound at all
Anyone could help me ?
thanks
Unread post by senso » 15 Apr 2010, 08:49
try the 5.15?
gurulogic
Unread post by gurulogic » 15 Apr 2010, 09:24
This doesn't address your problem, but if 5.15 doesn't help you could try Usine VST instead. You can do 99.9% all the same stuff with Usine VST in an inexpensive (free for 30 days) host like Reaper. A little more CPU used but it might give you a temporary solution.
Users browsing this forum: No registered users and 364 guests
