I'm using the version 5 of Usine with the grid mode and the sequencer at the same time. Each time i'm loading my workspace, i have an Internal error message ! and if i delete those files waves files i don't have this message while loading the same workspace.
The thing is that i'm planning to set up my live set and loading a lot a waves files and setting up loops so i want to be sure that this type of message won't block me at one point !
Is there a better place where i should store the waves files which will be loaded in the sequencer ?
Where Storing files for the sequencer ?
strange , did this error message in the console concern wave files you use in the sequencer or..?
maybe an external drive..?
noise2sine
Yes this error concern a wave file in the seqencer and this file is located on my laptop hard drive not on an external drive.
This pb looks strange.
normally you can store you can store waves anywhere on your computer, or network.
Files are stored in with their absolute path.
But if a file is not found Usine looks into (in the order):
1) the current patch folder
2) Usine/Files/demo folder
Users browsing this forum: No registered users and 473 guests
