It would be nice to be able to alt-drag to replace a subpatch. It's fine if you require the exact same inputs and outputs, as that is the general use case for me. It doesn't need to be any different than the VST version.
That said, mproving alt-drag to look for name/type rather than just position would be nice for inputs and outputs that are common to all VST plugins, such as midi in/out, audio in/out and program..... it limits the value of alt-drag when all the cables have to be reset because a vst has one less input or output.
thanks,
-e
alt drag to replace subpatches
- senso
the template engine will be improved as fast as I can.
