Phase problem with resonator
Unread post by cmodica » 26 Mar 2010, 10:35
I have made some radio creation with Usine recently. I use the patch ''resonator' made by Senso, i like your patch Olivier and i use it a lot.
This is how i worked :
I play in live mode at home and record all the track separetly.
So i have 9 tracks on my hard drive
I import them in Nuendo and make some mix correction and mastering.I am attentive to the phase problem because it is important for a radio diffusion. I use the RME soft of my Multiface II sound card : Digichek Oscillosscope
Each time i have to invert the phase of one of the two chanel (left or right, it is a stereo chanel of course) of the resonator track. Even this track is totaly dephase.
Is there a way to correct it in the resonator Patch ?
Unread post by senso » 26 Mar 2010, 12:01
The stereo width enhance the dephasing.
set it to 0.
But, this fx is based on small delay's which can produce strange phases results.
Unread post by nay-seven » 26 Mar 2010, 12:09
in each sub patches ( also named resonator ) you also have a invert phase option in the delay modules..?
Unread post by cmodica » 29 Mar 2010, 18:04
I tried to invert the phase of each delay module on right chanel in each sub Patches, but the stéréo sound still out of phase ....
I will try to set the stereo width to 0. It should be ok, but i'd like the stereo effect :(
If i find an other solution, i will tell you.
Users browsing this forum: No registered users and 256 guests
