Overlapping interface design objects : what's the logic ?
La Tenaille
Unread post by La Tenaille » 07 Mar 2010, 14:11
I put a led over a switch. It works until I re-open the workspace, then the led is hidden behind the switch. How does it work ?
Unread post by nay-seven » 07 Mar 2010, 14:39
yes, not easy..
put your led in a sub-patch..this will work..;-)
La Tenaille
Unread post by La Tenaille » 07 Mar 2010, 14:53
tested : ok :)
Users browsing this forum: No registered users and 439 guests
