osc send : iii
Unread post by 23fx23 » 07 Mar 2010, 06:25
is it possible to send for example 3 integer as iii, not 4?
in my case, if i use a 4data send on other side it doesn't receive/has another fonction than 3 ould. im blocked..any trick?
Ive tried to feed data1 input of one data only send osc with an array of 3 lengh, but this doesn't seem to work.
, maybe it's not the same to send an array than iii, or maybe the array send floats? (i put integers in it, but i suppose they are considered as float?
Unread post by senso » 12 Mar 2010, 11:56
will be possible in the next release V5.11 and above
Unread post by 23fx23 » 12 Mar 2010, 13:45
woa cool great!
