Midi Filter/transform
bmoussay
Unread post by bmoussay » 28 Dec 2006, 23:58
About the "midi filter module":
I think it would be great to have "NOTE ON/OFF" option in the filter list.
For the moment we have only NOTE ON or NOTE OFF, so when we want to filter a midi message keeping only NOTE events (ON and OFF), we need two midi filters plus some patching to achieve it.
Another great option (for me at least) would be to have a "MIDI CHANNEL" input in this module, allowing, for instance to change very simply the midi channel of a midi message (whatever message it is).
I actually managed to do a "midi channel change" sub patch, but it's quit heavy, since I dind't find any other solution than to use MIDI FILTER-CREATE MIDI couples to treat each possible message (NOTE ON, OFF, CC, PITCH, AFTER TOUCH, PC, etc...), quite a heavy solution (but maybe I missed some more simple way to do it ?).
Anyway I think it would be far more simple to have it all in one module, what do you other usiner think?
By the way thanx Olivier for the 2.55, it's great!
Rgds,
B.
Unread post by senso » 29 Dec 2006, 08:13
hello again!
this option already exists: 'ON/OFF/Pitch bend'
yes, good suggestion. But I think that it's better to add this feature in the MIDI TRANSFORM module? More logical?
I'm not shure, beacause in most situation it will cost cpu for nothing.
Add this option in the midi transform is the best solution?
