Infinite free wheel
La Tenaille
Unread post by La Tenaille » 06 Mar 2010, 14:13
Is there an infinite free wheel in Usine, or a simple way to create one ? I'd like a knob that controls a range VST parameter for example, without beeing stored in the conductor, and an endless knob seems to be the solution ?
I've already found that a button>toggle>pass if change>inlet of a VST switch, and a led on the outlet of the same switch does the job, and would be delighted to find an equivalent for a range adjustment.
Unread post by 23fx23 » 06 Mar 2010, 23:39
well that's not a true endless pot, but can work the same, if you clic and move in X of the panel, the output fader behaves like an endless encoder, hope it can help.
La Tenaille
Unread post by La Tenaille » 07 Mar 2010, 13:25
Hi 23fx23,
Thanks for the patching, I've reproduced and it seems to fit my need.
I didn't know image panel module. I'm going to use your solution, and post a suggestion of improvment for an endless pot in the interface design ;-)
Unread post by 23fx23 » 07 Mar 2010, 16:50
yes, true that could be handy in some cases... iwraped y head auround a bitmap solution, but still bit complicate..
Users browsing this forum: Google [Bot] and 385 guests
