Hi Usiners!
Just some remarks about the Midi IN module (in Usine 2.55)
1) In the "mode" list, a small bug: "channel 9" is missing, replaced with "channel 0"
2) I've noticed a strange behaviour of this module:
- when used in a sub patch, it "looses" its "mode" input and setting.
Rgds,
B.
Midi IN module
- senso
Thanks for the "channel 0" bug... fixed
I plan to change the midi handling in Usine:
create midi selectors in the input stage of the track as the audio selector:
The main problem is that we have to create 4 selectors:
1) for the midi notes device (ie the midi keyboard).
2) for the midi notes channel
3) for the remote device (ie controler)
4) for remote channel
still confused is my mind.
I need you opinion.
It's almost normal beacuse in a sub patch, the midi in module is only an 'inlet'. You choose the channel setting in the main patch and send received midi codes in to the sub patch.2) I've noticed a strange behaviour of this module:
I need you opinion.
