Hi
As I explained in another tpoic, I use 16 preset manager per patch (with 5 FX patch) and recall one the fifth first preset per scene of conductor (basicely, each song as a scene in the condutor, and for each song I have 5 mix & parameters of my 5 patch)
I get the num in the conductor by a bus and then, it activate one preset manager or another (the one coresponding to the scene in the conductor). So in front of each preset manager I have a module "=" wich activate or not my preset manager (to be precise it let "pass" the num from the pedal and the store button).
As you can imagine, it makes lot of modules and wires in the patch ... building it I got confused and I realised that the second value in the 16 "=" module are stored too in the active preset manager ...
So my question is what is the good way to have some values not stored into conductor or preset manager ?
Should I have a fader in my "=" second value and have this fader "not stored in conductor/preset" ?
Should I use an Arrtay ("not stored ...") or a constant value ?
Should I be more carreful next time ? Yes !!
I'll send my workspace tomorrow, when it's cleaned and nicely transformed from 4 to 5 ...
thanks
About Preset manager
