Would it be possible to split the mode (absolute/relative/toggle) of the key & midi learns? I've got F1, F2 etc keys set to track mute which needs to be a toggle, but when I assign my midi controller they need to be absolute to properly...
I've tried every possible combination of settings in my midi controller but to have the correct feedback state on the midi buttons the midi learn has to be on 'absolute', which means I then give up being able to use me F1, F2... keys - any solution Senso?
Key & Midi Learn modes?
maybe don't understand your problem but each midi or key learn can have a different mode..?
you can have 1 switch in toggle mode , one in absolute..?
Clearscreen
Really? As far as I can see in the remote panel I've got the 'F1' key and midi 'CC10' both assigned to the track 1 mute button, but there's only a single drop down for 'mode' - am I missing something?
ho, ok !
so , if you really need this , you can make a patch with some mixer track output modules( 1 by track )
link 2 switch ( group 1 ) to the M inlet , one with a key learn , one with a midi learn..
and different mode..
Clearscreen
Nice workaround Nay, but it'd be easier and quicker if it was in the remote panel...
let me think about this.
Users browsing this forum: No registered users and 35 guests
