I`m looking for some kind of a routing module which will have 2 inputs, one output and and A/B switch.
I want to be able to switch between two Audio signals flows in the same patch with a push of a button.
How can I do it?
Should I use the Switch module? (page 95)? or the Switch (sequenced) module (page 81)?
10nX
a/b switch
you can use the audio/crossfade module or the data/selector.
I think it can be simple?
how did I missed that in the manual ?!
10nX, the "selector" works gr8
