Strugling with a bar counter
I need a bar counter to know where I am in my song (in grid or IB mode)
I've managed to build a bar counter :
Clockbeat module -> +1 module with out back to A -> /4 -> int to string -> text
which works
My problem is that when I stop and restart the audio engine (with SPACE) my counter should reinitialize to 1
Is there a solution for this ?
tia
k
which works
tia
k
don't have try but i suppose you can use the dashboard module and use the outlet "on" with a 0to1 module...to send a 1 of a pass module ..
hmm the dashboard module hasn't a outlet 'on' ?
sure..?
of course it could be named " off" if you audio engine is off..
If you don't find a satisfactory solution in Usine, perhaps try Big Clock by Pizmidi.
http://www.thepiz.org/dl/?p=vst
@guru:
if you need a clock
if you need a clock
It looks as I don't find a solution, perhaps i'm not good enough at patching yet....
So I would be realy greatfull if someone finds a solution for my problem
I want a counter that counts up every bar, but each time I stop or start the audio engine (with SPACE) it should restart from 1
thank you
k
thank you
k
something like this..?
aha!nay-seven wrote:@guru:
if you need a clock
I am still stuck on my old skool VST solutions daze...
I must always remember that Usine can do ANYTHING! (well, almost
Close but not exactly
As I see it, the counter is reset at each cycle start, it should reset only on the first cycle start
k
k
ok , with the help of senso , found a way :
put this in your master section :
then add a bus sending the 1 to the reset of the counter..et hop
This works perfect !
Big thanks to both of you.
k
Would be nice for the WIKI ?
k
cool!
yes , could be an example for this characteristic of the master insert .
Users browsing this forum: No registered users and 44 guests
