Moving and deleting tracks and patches in V5
La Tenaille
Unread post by La Tenaille » 24 Feb 2010, 10:40
A few questions :
1. How can I delete a patch ? I have cleared patches in my tracks, but I can't delete the patch itself.
2. Is it now possible to change track order ?
3. I've noticed that when moving a patch from a track to another in grid mode, it creates an empty patch in the source track. Normal ?
... and if you have tricks, hints and advices about patches & tracks management I'd be delighted ;-)
Thanks in advance
Jacques
Unread post by nay-seven » 24 Feb 2010, 11:28
[ctrl+suppr] will clear patch as you know yet , and it's maybe a good way..?
_Remember you can move each patch as you want , even on an empty place
_Remember also that you can have different position for each patch in Interface Buider mode ( different than in grid mode)
_And don't worry for empty patch, if they are at the end of a track , it's the same that with empty track at the end, they will disappear the next time you load the workspace..
_Experiment also with the line features, add, select, delete...
La Tenaille
Unread post by La Tenaille » 24 Feb 2010, 11:43
Hi Nay-Seven,
I missed the information about puting the patches at the end of the track ;-)
The new "delete current track" function is great, I imagined something equivalent for patches in order not to have to restart Usine to do the job.
Thanks for your help.
