Usine and Cubase ?
reverba
Unread post by reverba » 20 Feb 2010, 10:53
I just discovered Usine yesterday, with a demo with a multi touch screen and it looks amazing.
But I have a question :-)
I'm currently looking for a tactil control board for my favorite DAW : Cubase.
Of course I see the jazzmutant, but I found Usine and it looks like really great.
So my question is : Is possible to use Usine for controlling VST, eq, insert, fader, pan, etc on cubase? like a Mackie universal surface, or Euphonix controller ?
Thanks a lot !
Unread post by nay-seven » 20 Feb 2010, 12:41
i don't see any problem with that , you can built your own interface sending midi message
and sending them to Cubase via a virtual midi cable ..;-)
amiga909
Unread post by amiga909 » 20 Feb 2010, 14:04
i wouldnt say its no problem if u want Mackie control.
Mackie MCU is a propietary protocol, means some advanced automations only work with Mackie (or similar) controllers.
there has been good work on making a behringer BCR/BCF act like a Mackie controller.
it should be well possible to make Usine act like a Mackie controller too - would be very kewl to have :)
http://www.geocities.jp/mackicrokontrol/
reverba
Unread post by reverba » 20 Feb 2010, 14:47
Yes I heard it about Behringer, but I prefer the multi touch screen feeling ;-)
I will try the demo version on Cubase 5, to see how it works :-)
Users browsing this forum: No registered users and 103 guests
