hi again!
example: i have 3 sample in my sampler,i want to be able to open each one with the markers corresponding to the selected sample ( the first one has two markers,the second three markers ,at different position,etc...)
thanks again!!
and to save a "map" of markers according to a specify sample?
a try :
( for the + module , b=1 )
excellent!
array are cool,i never used them...
thanks one more nay!
and if you want to edit your array easily , you can use this way :
this way you edit your markers directly on the wave display
then , you just have to cut paste this array, and do the same for next ones
whowww!
Thanks nay for this tip...I'm really a fool with arrays
Seb.Dub
