Using Usine with the Dave Smith Tetra
noise2sine
Unread post by noise2sine » 10 Jan 2010, 20:42
I'm using this synth which is mainly controlled by Usine (a lot of fun). The preset are organized with program numbers and banks. When i'm using the creat midi message module, i can change the program numbers using the program change option. But I didn't find a way of changing the bank number and the program numbers ? how can i do that ?
Unread post by nay-seven » 10 Jan 2010, 21:35
hello
generally, bank select message are send with CC 0( msb ) and 32 (lsb )
you can refer to the midi implementation of the Tetra to find good values..
use 2 or 3 ( if you add a program change ) create midi module and maybe an unpack script behind could be useful too
there's also the sys ex solution ( there 's a module for that too in Usine )
ethnix73
Unread post by ethnix73 » 10 Jan 2010, 21:41
Commonly, bank change is done with CC0 and CC32:
CC0 (0) + CC32 (1) should select the second bank...
But it may vary from synth to synth
Seb.Dub
noise2sine
Unread post by noise2sine » 11 Jan 2010, 11:32
Thanks i will try that, and let u know.
Thanks dudes
noise2sine
Unread post by noise2sine » 14 Jan 2010, 10:38
I have tried what u said , with unfortunatly no success. i must add that i'm very bad with midi understanding.... I have tried to read the manual, i couldn't find any information that i could understand .... Do u think it would be possible to have in the add on section a simple patch allowing those actions like changing program,subbank,bank ..... ( I will play on sunday :( help.....)
Thanks a lot Usiners
Unread post by bsork » 14 Jan 2010, 11:19
I've taken a quick look at the manual, and wonder what "MIDI Parameter Receive" mode you're using. You can choose between All, NRPN and "normal" CC. If I understand the manual correctly, you should be able to select banks by sending CC no 32 with a value between 0 and 3 if the receive mode is All or CC.
Or what about putting all the programs you use into one bank?
noise2sine
Unread post by noise2sine » 14 Jan 2010, 11:44
Thanks for yr attention Bsork !
So i will use : a create midi message set on "CONTROL CHANGE" with the "code 1" set to 32 the "code 2" set between 0 and 3 ? and for the "PROGRAME CHANGE" an another create midi message module ?
ethnix73
Unread post by ethnix73 » 14 Jan 2010, 11:58
Yes, you can use the same button for the two "create midi message" module. I think you have to put a "wait one cycle" module before the "create midi message" module sending the program change....
Seb.Dub
magickz
Unread post by magickz » 08 Feb 2016, 11:47
noise2sine wrote:Hello,
I am trying now the same with DSI Mopho. But still new to this. Would you mind to have me look into your patch to learn from you? Especially I do not understand yet how to use the NRPN correctly.
