[script] import script file
manecante
Unread post by manecante » 29 Dec 2009, 23:39
hi
is it possible to import an external *.script file into another script ?
(would be nice to make functions re-usable and clean up code which contains hundreds of lines ...)
martignasse
Unread post by martignasse » 30 Dec 2009, 03:11
hi manecante,
manecante wrote:is it possible to import an external *.script file into another script ?
I think the script engine has no import/include functionality (have to be confirmed by Senso, or Bsork ?)
ctrl A + ctrl V...
I mean, if you use an external text editor like notepad++, who can manage multi-files, that could do the trick ?
Just a through, but if you have pretty big script and begin to feel limited by the engine, maybe it's time to look into the SDK ;)
We put a lot of effort in the upcoming V5 to make it clean, accessible and even more powerful
Hope it help
manecante
Unread post by manecante » 30 Dec 2009, 15:21
hello.
1st of all, I have to apologize for using manecante account to post here but as I'm not an Usine user (just helping her with some code), I thought it would be easier.
thanks for your answer Martignasse but working with multi-files in emacs is not an option (having an "import" functionality in scripts would be neat though...).
looking into the sdk is also a non-go as I have absolutely no idea about non-unix system, but I admit that it would be definitively better.
cheers,
_yvan
amiga909
Unread post by amiga909 » 02 Jan 2010, 11:20
martignasse wrote:I think the script engine has no import/include functionality (have to be confirmed by Senso, or Bsork ?)
according to senso, 25.8.09, its not possible
http://www.sensomusic.com/forums/viewtopic.php?id=1646
