[script] ptTextField type
manecante
Unread post by manecante » 29 Dec 2009, 23:37
hello
Pascal n00b question:
I cannot seem to find the correct type for ptTextField:
Code: Select all
filein := createParam('filename', ptTextField);
I was expecting to get a String with GetValue(filein) but I get a "type mismatch" error...
it seems that I get 1 single, which is an ASCII value of the 1st letter of the typed in text.
am I wrong assuming that it should be a String (or an array of ascii chars) ???
if yes, how can I get the value of the string entered in the textfield ?
Unread post by bsork » 30 Dec 2009, 00:19
Here's an example from a file I think is in the AddOns (TextFile2Data):
Code: Select all
VAR filename   : String;
PROCEDURE init;
BEGIN
  pFilename := CreateParam('file name', ptTextField); SetIsOutput(pFilename, FALSE);
END; // init
PROCEDURE GetFileName;
  VAR i : integer;
  VAR c : String;
  VAR s : String;
BEGIN
  s := '';
  filename := GetStringValue(pFileName);
  FOR i := 1 TO (length(filename)) DO BEGIN
    c := copy(filename, i, 1);
    IF &#40;c <> '"'&#41; THEN
      s &#58;= s + c;
  END;
  filename &#58;= s;
  writeln&#40;'FileName&#58; ' + filename&#41;;
END; // GetFileName
Hope this helps.
Actually, I'm not 100% sure that you have to create a loop and copy the string one character at the time, but at least it works :)
manecante
Unread post by manecante » 30 Dec 2009, 01:04
hi bsork
great, this works perfectly !
and yes, you can avoid looping:
Code: Select all
var str_tmp &#58; String;
begin
     str_tmp &#58;= GetStringValue&#40;filein&#41;;
end;
but after a few hours of trying Pascal, it seems to me that you *have* to loop for about (nearly) everything :P
thanks again !
_yvan (obliged to write code by/for manecante)
Users browsing this forum: Google [Bot] and 25 guests
