1) It would make things much less tedious when building interfaces if it was possible to select more than one object in the IB and to move them at the same time.
2) Also in the patcher how about the ability to select modules with the mouse by dragging a box around the modules. This way you don't have to shift click every module that you want to move if you are moving more than one.
Appologies if this is already possible. I did not see anything about it in the manual.
3) Also, the ability to undo control panel and interface builder changes.
4) I'm not sure if this is a bug or not but when copying and pasting modules the caption text is not retained. anyone else having this issue?
thanks
interface builder and patcher suggestions
- senso
hello,soundmind wrote:1) It would make things much less tedious when building interfaces if it was possible to select more than one object in the IB and to move them at the same time.
thanks
1),2),3) I know, it looks strange that such features are not implemented yet. It's very basic for a software. In Usine It's not so esay and I'll improve this point as soon as I can.
4) fixed in the v5.
