I'm a great fan of the echoplexx but i think that the saving process is not really easy.
I'm giving an example for explaining my request :The base is recorded and then i record the four layers left. My request consist of just one button able to save the base and the four layers in the different samplers at the same time ?
i have another question : which is the best way for recalling the different base recorded with all the different layers with just one click ? preset manager can do the job ?
In case i want to use the conductor ihave to use a list box from file inlet of the sampler. Is it possible that the list box module can be automaticly updated with new sample recorded in the the sampler list ?
The Echoplexx improvement ??
"Is it possible that the list box module can be automaticly updated with new sample recorded in the the sampler list ?"
i would also find it usefull.
create an inlet,connected to 'sampler/save rand' in all layer sub-patch. Then connect them in a single 'save' button.I'm a great fan of the echoplexx but i think that the saving process is not really easy.
the preset will do the jobi have another question : which is the best way for recalling the different base recorded with all the different layers with just one click ? preset manager can do the job ?
the V5 will provide an efficient way to manage samples list.In case i want to use the conductor ihave to use a list box from file inlet of the sampler. Is it possible that the list box module can be automaticly updated with new sample recorded in the the sampler list ?
noise2sine
Super ! xmas 2009 will be great !
thanks again Senso for yr answers !
Have a nice musical day !
