New version (2.5). Major Update
Major Update
Usine 2.5 is split into two versions:
free: limited to 1 stereo input, 1 stereo Output and 4 tracks
pro : 10 stereo inputs and 10 stereo Outputs and 16 tracks (price 50 Euros)
new features:
24 bits wave files compatible
new interface design
short fade in/out on track mute, solo, on/off (posted by lalo)
rename file button in sample list
copy/paste list in sample list
now you can change the name of a track (!)
local Host OSC monitoring allowed.
next prev track button in global remote
next prev grid line button in global remote
[on change] inlet in OSC receive
[set to zero] inlet in data dispatcher
[clear list] inlet in the sampler
new modules:
Audio to Midi native (analysis)
Array Queue Data
Array Sort Array
Array Swap values
Array Get Value
Array Set Value
Array Get Length
Array Sum
Array Mean value
Array Standard deviation
Get Usine Bloc Size
Get Sample Rate
Math Power Scale function
Multiple Variable
Data mapper Curve
Data mapper values
fixed bugs:
conductor append and midi learn (posted by B Moussay)
vst plugins with lots of parameters (posted by lalo)
some patches are loaded without connection
Notes:
For early fans, the old activation code is still functional.
new features:
new modules:
Array Queue Data
Array Sort Array
Array Swap values
Array Get Value
Array Set Value
Array Get Length
Array Sum
Array Mean value
Get Usine Bloc Size
Get Sample Rate
Multiple Variable
Data mapper Curve
Data mapper values
fixed bugs:
Notes:
That looks startlingly great, what an update!
Thanks!
I can't wait to dig in and come back to comment!
Thanks!
Nice, can't wait to run this.
Vonbrucken
- New member
THANK YOU
MERCI
MERCI
Users browsing this forum: No registered users and 190 guests
