Great Gig & Control surface
TomWard
Unread post by TomWard » 04 Dec 2006, 14:47
Hi Senso,
I saw your gig last night with Stephane Payen at the Vortex in London - it was really cool, I think your software is really exciting. I've just downloaded it, but I'm on an Intel Mac, so it's going to take me a little while to install Windows so that I can try it out...
Just a small thing - what were those control surfaces that you were using? They seemed to be ideal, motorised faders, lots of knobs, etc.
Have fun,
Tom
Unread post by senso » 04 Dec 2006, 21:11
hello,
It was very nice to play in London.
The public was listening attentively.
Usine works perfectly with mac Intel under windows.
On stage, I use Behringer controlers
BCF2000 for track mixer,
BCR2000 for patch parameters.
Cheap and robust.
Vonbrucken
Unread post by Vonbrucken » 21 Dec 2006, 18:08
how long are your gigs ? can you make a one hour performance with only usine ?
and by the way is there a way to smartly disable effects that are not in use ?
i am just begining right now to discover the soft though i had downloaded from a long time
thanks for your answers
Users browsing this forum: No registered users and 272 guests
